paulspaddle
- Joined
- Mar 2, 2009
- 753
There seems to be a subterranean water flow below our property.
It's hard to see how thick that ice is on the shore from the pics and not knowing the shore in the summer. The deck on the shore is typically 4 feet above the water, the ice is nearly level at the moment. It's squeezing through the boards on one corner.
You can see the build up of ice as the water flows onto the shore and lake then freezes.
The temperatures this weekend were -5 to -10 C and there was wet water on top of this ice.
What I think is odd is our property sits higher than the other properties in the bay, but this is only happening in front of us.
Its been an odd year with a high water table which may be a contributor to this.
Do you think there is reason to be concerned about this? Can a subterranean stream cause the shore to collapse? It's limestone and sand.
Thoughts/Opinions?
http://i913.photobucket.com/albums/ac331/paulspaddle/IMG_5259.jpg
Thoughts/Opinions?
