1986 Yamaha 150 HP Yamaha
Safebet
I have just purchased a boat with a 150 HP Yamaha (1986) engine that has not been run for 5 years. It was running fine when stored.
What are some of the first steps I should take to get this motor running, again.
Thank you
Jim
robert graham
Re: 1986 Yamaha 150 HP Yamaha
I'd start by getting all the fuel out of the tank, lines, pumps, carbs, everywhere. Drain the carbs, change oil in foot, replace water pump impeller, new plugs, fresh fuel with a heavy dose of Stabil Marine. Should be ready to go! Good Luck!
Safebet
Thank you, Robert. I appreciate your prompt reply.
I have copied you list and will do as you say. Will report the outcome. Probably be a couple weeks. Tight schedule.
Thanks, again.
Jim
