1973 Merc 850
egclassic
I have been working on getting this motor running. Not sure how long its been since this engine has ran, since I just bought it a month ago.
I have already replaced the internal wire harness and all of the fuel lines. Yesterday, I finally tried starting it. Took many, many times but it finally ran, but I had to immediately shut her down as no water was coming out of the "pea" hole. I am dropping the lower unit today to begin replacing the water pump. Just wondering if there is anything else I should do/look at while I have the lower unit off?
coolguy147
Re: 1973 Merc 850
not while the lower unit off. but should check and replace gear oil when it is back on.
check compressoni
if it hard time starting i would do that^ then check spark then clean carbs if all check out ok.
Re: 1973 Merc 850
Clean the carbs and check the timing (link/synch)
