86' 115 v4 vro johnson thermostat location
ezeke
Re: 86' 115 v4 vro johnson thermostat location
The large hoses leading from the bottoms of the two cylinder heads run to the thermostat housing. The thermostats are inside.
Iboats sells a kit with everything normally needed to service the crossflow thermostats: 18-3673.
back of the motor down in bottom of lower cowl , between heads. model # of motor, the did not make a 115 in 1986.
