Ok so I posted regarding an oil leak on the drain at the bottom of the outdrive. So being that I just want to be safe rather than sorry out in the middle of nowhere I wanted to do as much as I could to the outdrive to be more confident about taking trips out with the family.
So here is where I'm at. I removed the outdrive and I'm getting the bellows for ujoint shift cable and exhaust. Water pump kit with impeller and new gaskets all the way around. Checked the gear oil with a rare earth magnet and no metal came out ecxept very small metallic like shavings. Nothing that stock to the magnet.
Please, thoughts or suggestions since i'm here what do I replace now that I have it apart.
And should I post pics as I go along or just create link to an album?
Almost forgot, all looks ok except I found a large piece of corroded metal that does not seem to belong anywhere. (FIRST PICTURE)
Draining gear oil not much came out and no large metal shavings.
removing trim after taking prop off
bellows
lower (where water pump)
water pump gaskets Where is the oil from????
comments and suggestions please. I don't want to take too many trips to West marine its far from where I"m at.
Like always, I very much appreciate your opinions.
bellows
