I reversed battery polarity, now it won't start
HerbieJ
Tried to hook up a battery while lying on my stomach under the boat cover, in the dark. Realized I had reversed the battery terminals as soon as I touched the second cable to the post and saw the little orange sparks. Now I have no power to the engine, except the tilt/trim switch. Can't turn it over. What did I do??? What will have to be replaced?
HerbieJ
1995 Mercury Mariner 4 cylinder, 4 stroke, 50 HP.
j_martin
Re: I reversed battery polarity, now it won't start
HerbieJ
There's probably an inline fuse under the cowl near the solenoid. Reverse polarity on the rectifier would have blown it. Hopefully that's the only damage.
hope it helps
John
slasmith1
check all fuses and circuit breakers if they did their job it should be your only problem.
HerbieJ
FOUND THE FUSE!!! Problem solved. Someone please cancel this post: I don't know how.
HerbieJ
Barnacle_Bill
Check your charging circuit now. There is a chance you blew a diode(s) in your rectifier.
