- Joined
- Mar 5, 2006
- 30,838
Re: Two batteries wired in parallel
First of all, the ACR only connects once the voltage of either battery gets up over a set threshold so it will not turn on with only the ignition.
Second, each battery will get the charge it needs based on how low the battery is. It will not matter what the size or capacity of each battery is as long as each battery is the same construction type(both agm or both lead/acid).
Both of these statements are just wrong.the acr serves the same purpose as the isolator except that it does not isolate the batteries with the ign on and two unmatched batteries should not be charged in parallel
