1989 150 Evinrude 150 crossflow
80 old man
everything seems great except neutral idle speed. I have set linkage, checked throttle valve adjustments and timing. Sprayed for leak in carb gaskets but idle speed in neutral will not come under 2100 rpm. Suggestions?
80 old man
Dhadley
Re: 1989 150 Evinrude 150 crossflow
Can we assume the timer base is going all the way back?
emdsapmgr
Does the sync and linc allow all the carb butterflys go completely closed? Check each carb, also make sure the middle carb roller has no pressure on it. Is the quick start feature working properly?
