jasoncolley
Thread starter- Joined
- Feb 2, 2010
- 6
Hi guys can someone please help me, I recently purchased this Johnson with no know history, but had good compression and after some fiddling and new parts it starts and runs fine, but no water came out of pee hole, so I removed lower drive unit replaced impeller and stringy gasket and rubber cups (old impeller looked good nothing broken) I also found that I could not blow through pee pipe so I removed it and with a hand pump seemed to remove the blockage, I then put the lower unit back on and started the engine in water but still nothing only exhuast fumes from pee hole, so I took leg off again checked I had assembled pump correctly and that impeller was still good and installed clockwise with the key in place. Then as a test I put lower unit in water and connected a drill to drive shaft turning it clockwise it pumps water and I can get it to squirt higher than the drill on drive shaft end (used rubber pipe no damage to drive shaft) I also put a hose pipe on mid section water pipe that feeds the power head with water and managed to get a small steady stream of water from pee pipe, put it all back together and run engine still nothing from pee pipe! So today took lower unit off again but have not taken apart pump did drill test using muffs and tank and it definitely pumps water when drill is turning at say around 2000 rpm but how much should it pump? I tried flushing from pee hole back and then from water pipe up and kept alternating between there does appear to be more water coming from pee hole now but only once water has been running for 10 - 15 seconds, I am just not sure if there is still a blockage I am sure there is a thermostat and I would have thought once the engine gets warm it will open allowing more water to pass around head will this affect pee hole volume? I don't think so but does anyone know? Shall I buy some central heating flushing agent and squirt it in pee hole? Is there any other test I can do to pump or pee hole? Any help greatly appreciated Jason.
