I'll try to make this simple as I've read many posts in this forum and they are extremely helpful and appreciate everyone's input. My problem does not seem unique based on everything I've read.
I bought a boat that I believe wasn't operated much in the last few years but have no idea of knowing. The boat has 61 hours on it and is a 2001. That's good but this is bad:
The high pressure pump whine occured the first time out. It actually went out so I replaced it. Knowing that this wouldn't solve my problems as the whine was probably due to starvation, I disassembled the fuel cell carefully and found the inlet screen to the low pressure pump filled with paint from the housing. The paint was flaking above the float so I removed all the paint and clean the inlet screen. Boat ran much better but get's up to 4000 RPM and then slowly bogs down and will run all day at 3000 RPM. I suspect the low pressure pump is beyond recovery with paint and fuel gunk internally. I've replaced the fuel/water seperator 3 times and inspected the tank. No debris in tank, anti-syphon valve is good, fuel pressures are good and vaccum is good (checked only at idle). Replaced the plugs but did not check compression. Engine runs great at idle and when not under load but like I said, the RPM's drop once I get around 4000-4200 RPM.
From reading many of these posts I think a new fuel cell assembly will fix the problem but would prefer to only change the low pressure pump.
Question: There are many low pressure pumps available for Volvo VP's but where can I find one for this engine? Can I use a Sierra pump that has the correct PSI?
5.7GSI PEFS S/N 4012025441
Any help in locating a low pressure pump would be appreciated or if you have any troubleshooting suggestions for the engine bogging down above 3000 RPM under load, please let me know. I think I'm on the right path but I'm an aircraft mechanic not a marine mechanic!
Thanks to all, very informative forum!
