Recently i picked up a 45HP Chrysler (not Magnapower) in absolutely mint condition. I believe the motor hadn't been started for many years and the lack of spark pointed to an inspection under the flywheel.
I struggled with the removal of my flywheel. Three damaged pullers later i finally had the elusive "pop" and access to the points (As part of the removal process i absolutely flooded the shaft in WD40 and a penetrator substance). Now i cleaned the points and hastily reattached the flywheel in the hope of the motor kicking over. However there was still no spark. So now i am wondering whether the large amounts of fluid on the shaft from my efforts to soak the flywheel to aid in removal could be responsible for no spark. I have since removed the flywheel again and cleaned (removed all traces of the fluid). But i can't bring myself to reattach the flywheel only to find it yet again needs removal.
Any advice
Dan
Any advice
Dan
