findinghomer
Thread starter- Joined
- Nov 7, 2009
- 382
i just purchased a 15.4 in lcd hdtv/ dvd combo for my cuddy, do any of you have any recommendations for an outdoor antenna to receive over the air signals?
did you buy one with a digital tuner? without you will not get a signal anyway. unless your get a separate converter.
Shakespeare has the best ones IMO.
The one I use is similar to this:
http://www.shakespeare-marine.com/antennas.asp?antenna=2020-G
Any TV now will have a digital tuner. The whole reason for the switch-over was because there are no longer tv's made with an analog tuner.
omg... thanx for the suggestion, really not an option though, way to expensive.
'Ya just gotta be a little creative!
Look here:
http://orlando.craigslist.org/boa/1566970065.html
and here:
http://sandiego.craigslist.org/csd/boa/1580657521.html
Not all TVs come with ATSC(high Def) tuners yet althouigh most of the newer models do. I was just looking at a 46" model the other day that only had analog.Any TV now will have a digital tuner. The whole reason for the switch-over was because there are no longer tv's made with an analog tuner.
the changeover had nothing to do at all with tv's not having analog tuners.... in fact most still do......explanation
If you must have HDTV on your boat just spend the $'s and do it right.
http://www.iboats.com/KVH-TracVision-M2-M3-Satellite-Systems/dm/*******.644872145--**********.508108450--view_id.359378
Same thing. All digital broadcasts are highdef capable and there are no digital tuners that cannot pick up highdef.I didn't say they had highdef tuners, I said they have digital tuners...
The reason the government made the switch over to digital TV only and got rid of the analog channels is so that extra bandwidth is made available for other uses.
Totally agree, The TV broadcaster has to broadcast digital but it can be a lower definition such as 480p. My point was same exact tuner is used for all resolutions be it 1080 or 480. Not sure why every exchange with you becomes a pissing match...and its not just with me. Its with many others.No it's not the same thing... Being digital does NOT mean it's HD.
As far as googling is concerned, I have desiged many types of QAM receivers so I know more than a little about about the transmission of digital signals.
I will find the model I saw and post it. It was on sale at WalMart.
I'm with the tile man on this one![]()
No it's not the same thing... Being digital does NOT mean it's HD. Also, HD has been broadcast by locals who chose to do so for years, so obviously it doesn't have to be digital just because its HD
