Re: No spark No Fire
...do you mean straight from the battery or from the on switch key, my plan was running it straight from the battery to the 2nd fuse box. I don't have a accessory on my switch key, I got on and crank. I was going to put a kill switch between that in case I need to kill all of that if need be.
I like to run 2 batteries in a boat.. Can't get out and push
When you have 2 batteries you should also have a battery isolation switch. Something like this...
They have 4 positions, 'OFF', '1', '2', 'BOTH'. Sort of self-explanatory.
On the back you will see 3 terminals, '1', '2', 'COMMON'. Connect battery #1 to '1', Battery #2 to '2', and the engine cable and the accessories cable (the one you'll be running up to the fuse panel/s) the to 'COMMON' terminal.
All this gives you the flexibility of a 2 battery system and the ability to isolate the batteries, not only from the load, but completely. When I set up battery systems this is the only system I use. I also run the accessories power wires to a red and a black terminal block. Like these...
All electrics that are not part of the engine manufacturers package get routed through these terminal blocks, no exceptions!
DVA meter isn't bought at a auto shop, they are the exclusive domain of outboards. give me a couple of days and I will design a simple circuit using components you can buy at any Tandy. And it won't cost you any more than about $5
Chris...........
