Paint question
ron755
I am about to paint my boat trailer. all I have ever used is a spray can. I have bought a new HPLV spray gun, but have never used one before. What kind of paint, and thinners do I use , and what ratios? I want a gloss black.
BigB9000
Re: Paint question
you can buy the rustoleum in a gloss black gallon. same stuff as your spray can, at home depot.
which kind of gun did you buy?:
the siphon feed
or, the gravity feed
Depending on what kind of paint you buy, oil or water based, you can go with paint thinner/acetone, or mineral spirits/water.
the ratios don't have to be perfect. Usually that is something you figure out as you go.
As far as cleaning the gun, if you used oil based paints, use oil based solvents to clean. water based, use a water base.
NEVER mix the 2. don't clean water with oil, don't clean oil with water. It'll turn into a gunky mess.
and, when pulling out the rear most adjustment knob, you can pull out the air/mix needle. be VERY careful with it, do not bed or drop it. if you do, buy a new gun, you'll never find a replacement.
First, get the feel of your gun, fill it with water, connect it to your air compressor, and start spraying.
there are 2 adjustment knobs, the rear one adjusts volume, the side one adjusts your spray pattern. play with the knobs (one at a time) while spraying some water into the air. you'll see what I mean.
you can move the tip of the gun to have a horizontal, or a vertical pattern.=
Then, go paint (or water down) some clean brown card board. you'll get a better understanding of how it works.
When I first got one I was quiet disappointing with my work, and tried to blame the gun. then my father came along, did some adjustments, and the car I was painting came out perfect. I could never duplicate that for the life of me. But I guess that is what you get after 40+ years experience at spraying.
also, the air pressure must be correct. if your gun calls for 40 psi, don't be putting 90psi out of the compressor.
jeeperman
Re: Paint question
umm not to discourage you but gloss black seems to magnify any itty bitty imperfection in the surface to be painted.
For a beginner in spray painting you might be highly disappointed in the results.
john from md
Re: Paint question
I agree with jeeperman and suggest not painting gloss black. It shows everything.
John
a70eliminator
Re: Paint question
There's not much open realestate to a trailer, spray gun is a good method as it gets paint into all nooks and crannys that is otherwise a pain to get with a brush, gloss black is a good choice, getting into the corners is the important part, trailers are pretty forgiving when it comes to imperfections, runs and sags aren't a big deal, just get a good enamel and thin according to instructions on can, you also add a hardener, you'll have to go to a paint shop to get it, sometimes in the paint section of farm and fleet or tracter supply will have the hardener.
