firefighter384
Thread starter- Joined
- Feb 11, 2010
- 4
I have a 1991 johnson 140 it is hard to start I have to hold the throttle open about 1/2 inch. Once I get it started, and it warms up it idles fine. at WOT it will only do 4000 RPM, and that is only with help from the other engine. It wil runn all day long at 4000 with no problems. Same prop as the other engine, only difference is the slow one is the counter rotating prop. Compression is good 115 all cylinders. The right hand engine does 5200, and you can feel a diefinite acceleration when you hit the right hand throttle, as where I do not feel a strong throttle response from the left hand slow engine. Have held the throttle wide open by hand with no better results.
