deerhunter2504
Thread starter- Joined
- Feb 15, 2010
- 2
Please help me if possible. We took the boat out on the lake and was running perfect for about 4 hours. Took a break and went to start back up and made a loud backfire noise and has not started since. Wiring was all redone about a year ago so wires are not old. The motor has 115 psi in all 6 cylinders, all spark plugs are firing fine. Usually i can spray a little gas in carb to jump fire it off and that works, but now I can spray gas in carbs and nothing happens. It will sputter like it wants to start but will not crank up. If it is getting spark I do not understand why it will not even fire off. I was told if i am getting spark to plugs this is not an electrical problem. Is this a carb problem? I need help. Please help me. Thanks
