mercruiser 3 ltr swap with 4.3ltr
wenzupacelli
Hi I have a rinker 182 with merc 3 l and would like to install a 4.3 the boat have engine supports for the v6 but the problem is that the v6 does not fit in the engine comp hatch for 1 inch on both sides(manifolds too wide)i was looking to get these one piece aluminium manifolds but i dont know if i will get that 1 inch from both side to make it fit.
any suggestions someone!!!!!!!!!!!!!
Re: mercruiser 3 ltr swap with 4.3ltr
Ayuh,... Changing manifolds will Not help...
Don S
You are also going to need an exhaust Y that attaches to your transom shield, and don't forget to change the gear ratio in your outdrive.
achris
More fish than mountain goat
... the problem is that the v6 does not fit in the engine comp hatch for 1 inch on both sides(manifolds too wide)...
If it's a fibreglass hatch, just cut it down the centre and widen it by 2". Set a sheet of ali in the middle and start glassing.
180shabah
Agreed, make the lid bigger, BTW - achris, good to see you active again.
ENSIGN
Make sure to leave enough room for repairs and maintinance(plugs,starter,winterizing) It would be a shame to have to pull the engine out just to do a tune up.
Bronc Rider
Adding some width to the dog house is a good idea.
One thing I have noticed on some of the smaller new boats is that the seating arrangement has to be different for certain engines. For example, the 3.0 on some boats can be had with this type of seating:
On some models if you upgrade to a 4.3 or bigger they make you get the second pic type of seating arrangement.
The second pic would require you to completely change the back seating of your boat. It might not be worth it but it might make engine access better. As ENSIGN points out, you're going to want to be able to reach parts that require service. On some boats the whole bench seat and lounging/tanning area can be on one hinge. Easy engine access on a set up like that.
jkust
What year is you Rinker?
