Fossilized
Thread starter- Joined
- Oct 31, 2009
- 15
This is my first boat & first fiberglass project.
This forum has provided hours of reading enjoyment and excellent info - thanks to all.
The floor is out of the boat. transom is clearly rotted. Stringers are a mixed bag - looks like rot started at tops - all are partially rotted.
I plan to replace full transom and all stringers.
Boat has 2 inner 12" high stringers & 2 outer 8" high stringers ~ 17' each interrupted by two bulkheads.
Plan is to use:
local clear pine 1" for longitudinals & 3/4" exterior BC ply for cross pieces, transom & floor.
DB1700 for all glass work
tab stringers with 1 piece of 6" on each side
cover stringers with 1 piece extending 6" on each side over the hull.
transom tabbing to be 1 -4" tab & 1- 8" tab
4 layers on transom for skin overlapping ~6" on hull
floor perimeter tabbed with 1 -8" & 1-12" tab
floor covered with 1 layer of glass
using epoxy
all wood to receive 1 coat, some to get glass + another coat
3/4" ply floor combo of 3/4" & 1/2" for seating & interior panels
I think this will take:
1 roll of DB1700 in 50" width. This is 67 running yards and cost about $300 + shipping
30 gallons of Epoxy costing about $1000
Total cost of wood, resin & glass is about $2,000.
Do you think this is a good plan?
Thanks
Plan is to use:
using epoxy
Thanks
