Outdrive wont go up
fishrdan
Re: Outdrive wont go up
adults section?
As BT and Don said, Adults Only thread, it's a sticky at the top of this forum. Download the manual you need (there are a bunch of them) and do some reading and troubleshooting.
The problem might not be your remote control/shifter, could be a cable problem, sounds like you need to do some trouble shooting. Word of caution, don't go willy-nilly taking the shift cables off the transom plate as they require precise adjustments, spin one of those barrels 3-4 times and it could mess up how the drive shifts.
The switch in the picture is the shift interrupt switch.
If it were mine, I would remove the lower shift cable from the transom plate and see how the drive shifts in-out of F&R, and how the remote control works with the lower shift cable removed. ***Paying close attention to how and where the cable was oriented and the position of the barrel nut so I could get it back exactly as it was before.***
If you don't know what the lower shift cable is,,, time to do some reading...
Powerstrokinc
yep i will pull that cable off in the morning and see if it shifts easier, i am also going to check the cuttout timing switch too! Thanks for the help, i just hope i can figure all this out without taking it in!!!
achris
More fish than mountain goat
... cuttout timing switch too! ...
Shift interrupt switch... Please get the names of parts correct. We have just been though a long saga in another area of the forums where people were using the wrong names for parts... wasted a lot of time.
achris
Shouldnt matter if the engine is running or not right? I cant get the throttle selector to come out of forward now, so i cant start the boat
You shouldn't be selecting gear without the engine running (or someone turning the prop). If the dogs (in the lower gear housing) are lined up high-to-high, then you could break a cable.
Chris....
Powerstrokinc
Pretty sure i have the right name to the box, i found it on the service manual
Checking Cutout Switch Timing
