markfromohio
Thread starter- Joined
- Jan 31, 2010
- 16
I finally put it in a tub and fired it up.. I rebuilt the carb and blew everything out with air. I turned it over and the float valve seated and i couldn't blow through it. started right up and runs great at high speed. But when i throttle down it stalls right away. I adjusted the needle valves the way it said in the manual. Says 3 quarter turn on each. And I tried adjusting the low speed valve each way and it doesn't seem to effect it in any way. I did reuse the old float as my kit didn't come with one. any suggestions befor i tear back into the carb?
