tkartmazov
- Joined
- Feb 23, 2010
- 9
Hi All,
I've been reading lots, finally registered to post
A formerly mentioned motor (J70ELCIM) came my way, been sitting for 2 years. Starts on 1/2 turn every time, idles fine after I adjusted the big idle screw, has a nice solid stream out of the pee hole, no visible leaks of any kind, all grease and lube seems normal. However, when under load, it seems to choke. If i throttle up without engaging the drive, the motor spools up beautifully to any rpm desired.
Spark is good, compression around 120 in all three, carbs look brand new compared to the rest of the motor (although i haven't taken them apart yet).
My question is: other than the carbs (i just ordered the parts for a rebuild of all three), could there be anything else causing this? And if so, is there anything I can potentially diagnose while waiting for parts?
Thanks in advance for your help; this is a great site with lots of very useful info!
