pete44
Thread starter- Joined
- May 7, 2005
- 189
Re: 87 SeaRay BR Innards
Erik,
I do agree..When I pulled off the sides just one side coated..Do you think I should rip out the foam? I have "tested" it with a clothes hanger stabbing around and is dry so far..I am just trying to save money..If I rip foam out someone mentioned you could use the "pink or blue" sheet foam from Home Depot and "stack it" to fill voids...Also, do you know of a good place to buy Epoxy resin at a good price?...I heard Epoxy resin "bonds" better then the polyester resin to existing resin/deck....And lastly, If I would have had enough since over the past 3 years I would have raised the boat/trailer as much as possible to keep water drained out through bildge..those trailer jacks do not raise it high enough for water to drain out. Should have placed tongue on a sawhorse (old school way)..This WAS a garaged boat until I moved...no room now in garage thus exposed outside with so-called cover on it....I say so-called because water still gets inside...You could see it drain out of bilge plug hole after a rain....Sorry so long...just venting I guess...This boat was in TWICE as better shape when garaged...Weather eats at it like cancer!
Thanks,Pete
Deja vu... reminds me of the two Sea Rays I've gutted.
Plywood sheets barely or partially covered in spray glass, questionable glass work all around, holes in the deck where foam was injected (and water can get in), plenty of places for foam to get wet and never dry.
Don't get me wrong, I like the hull styles from Sea Ray (at least the ones before about 1995) but they sure didn't build boats to last, they built 'em for cheap construction using cheap labor.
Erik
Erik,
Thanks,Pete
