Replace manifold or just riser?
ajarvis
I have twin 255's in a 79 Sea Ray 300 Sedan Bridge. I was going to replace the manifolds and risers but reading some posts I had a question. Should I go a head and replace them all or just the risers? I know they can rust through and cause havoc. How often should the riser gaskets be changed as well? I don't know how old they are, it would be good to know I was starting with new, good iron. Any help would be great
achris
More fish than mountain goat
Re: Replace manifold or just riser?
I have twin 255's ...
255 whats? Mercruiser 255 was 1973/4, and as you said 1979 boat,,,,
Need more input.... :D
Chris........
havasuboatman
Ensign
Why are you replacing them? Don't do so out of hand, take them in and have them checked out.
jerryjerry05
Iy you are worried then REPLACE!!!! Salt water??? Then definatly replace.
Being as they are possibly 30 years old and you aren't sure of the age then replace.J
zbnutcase
I would replace both riser and manifold,expensive but far cheaper than a new engine. 'nutcase
Risers don't last nearly as long as the manifold. if you think the manifold needs replacing then you definitely want to replace the riser.
ajarvis
Thanks for the replies.
achris-This is a 1979 Sea Ray 300 SDB, the registration says 79 but the docs fron Sea Ray saythe hull is a 78. It has twin 255 Mercrusier inboards, they were available in thoes years.
Ill pull the manifolds off and have them checked but replace them if there is any question.
Its run in salt water, how often do you guys think the risers should be changed and or the riser gaskets? Thanks again
achris
Quite right.... I was assuming they were stern drives... My bad...
Risers (elbows) should be pulled at 3-4 years, depending on use, then replaced with new gaskets.. Usually they last about 4-5 years, then corrode out. Manifolds usually last 10-12 years, again depending on use.
That's my experience anyway...
Chris.......
havasuboatman
Ensign
The reason the hull year is different than the model year is because the last two digits of the HIN are the year the hull was fabricated. Legally, the boat can be sold as a later model, but only by the manufacturer, with a certificate of origin, and it has to be a new boat, of course.
ajarvis
Thanks for the info, it's good to get others input. Have a great day and safe boating!!:D
