changing alternators
RLF
Im replacing my alternator on my volvo penta aq225e which has a paris Rhone 12v 50amp . I looked and found a replacement but its 105 amps. Now my boat doesnt have any extras as of yet but I will be putting in GPS, marine Radio, CD player and others. what do I need to do to change to the 105amp
zbnutcase
Re: changing alternators
Cannot say without more info on the 105 amp alt but it is a worthwhile upgrade. 'nutcase
RLF
its a paris rhone replacement alternator but its a higher amp. My question I guess Im trying to ask "Do I need to upgrade wiring for the higher amps or will the old wiring be sufficient?"
achris
More fish than mountain goat
Personal, I'd run a new (heavier) wire from the alternator output to directly to the battery (or battery switch if you have one)...
Chris.....
rodbolt
the output wire may need changing and any battery isolators or automatic combiners need to be checked for amperage ratings.
havasuboatman
Ensign
Is that 105 amp alternator an automotive alternator? If it is, you are endangering yourself and your passangers by putting it in your boat. 105 amp alternators are used in trucks and vans. 50 and 55 amp for boats.
If there isn't a marine rating tag on that alternator, it's not a marine alternater.
