66 evin lark8,no fire on top cyl plug wire
glassmaster68
couldnt get it to start,running good a couple of weeks ago,,now no spark on top cyl,,,what to do?
Yepblaze
Re: 66 evin lark8,no fire on top cyl plug wire
Pretty common to just take it apart and replace components on those.
The coils will actually crack, points wear, condensers fail, or wire loose a connection.
You can still buy the entire package of components at a reasonable price through most sources. Even here at iboats.
glassmaster68
is that everything directly under the flywheel where the plug wires go to?does anybody have any pics of what the coil looks like?,,is it on the side?
lindy46
There are two sets of coils, points and condensers mounted under the flywheel. You need to pull the flywheel to get to them. You'll need a harmonic balance puller to remove the flywheel and a torque wrench to properly torque the flywheel nut once you put it back together. A factory service manual would be a good investment if you plan on working on the motor yourself.
glassmaster68
so,i need to order a manual,tune up kit,2 new plug wires,,and 2 coils,,,2?
Yepblaze
Spot on.
and the tools
lindy46
It may take some effort to remove that flywheel nut as it is torqued to 105ft.lbs. I just removed one from a '66 Lark and it took an impact wrench to free it. When putting it back on you need a way to keep the flywheel from turning. A strap wrench or nylon strap ratchet will work. I usually wrap the nylon ribbon around the flywheel and secure it to the boat or motor stand and ratchet it good and tight. Good luck!
glassmaster68
got the tools,,just never worked on a boat mojo before,,, newby,,,,,,thank you guys so much,,ive spent alot of time on these forums,sure am glad its here,"lost" would be the appropriate word for me,,, if it wasnt for all of you on here,,thanks,,,i can tell someone has had the flywheel off before,cause the nut has some old rusty slip marks,,,but im sure its prob had a couple of sets im replacing since 66,,,,i can see under tho,,and it looks pretty old under there,plug wires on the showing part look new
