Question on 1983 Mercury 150 BlackMax
1974Revenge
Hello, I am buying a 21ft boat that has this motor on it and wanted to know if there were any specific issues I should look out for and check?
I will not be able to do a seatrial, only hear it run on a hose.
Also does anyone know what type of fuel economy these motors get as well as the reliability?
Thank you in advance for any help!
j_martin
Re: Question on 1983 Mercury 150 BlackMax
Black max means it's painted black and is a honkin' engine. Doesn't even verify it's configuration, much less displacement.
If it's a v6, likely it's a 2.0l. They are pretty solid motors but need to be maintained, or can get expensive. It's pretty hard to tell their condition onthe muffs. If you could do a compression test, and it's good, anything else is pretty easy to fix.
hope it helps
John
1974Revenge
Sorry about that...I do not know the specs on the engine.
I am attaching a photo if that helps at all..
Thanks for you help.
1974Revenge
What should the compression test show?
j_martin
Yep it's black.
Compression 120 ish. even is most important. If one is lower than the rest by more than 10%, it's trouble, major mechanical.
1974Revenge
Thanks again.
Any idea what the fuel consumption is on these motors?
I only have a 40 gallon tank.
