greengiant
Thread starter- Joined
- Mar 1, 2010
- 2
Need some help with the 1988 150 evinrude, the motor does not crank well but when initially cranked and warm it will idle ok. Later after running it WOT, and then stopping, it just will not fire/crank. Checked fuel primer bulb and it was not primed....reprimed and motor would fire but not start until I used the hot foot to give it gas. A mechanic suggested putting in an electric fuel pump. I understand there may be some restrictions/laws on when an electric fuel pump may be used. Someone else suggested replacing or repairing the fuel pump. Additional info: Compression on cylinders 1-5 is 90, 6 is 85. What to do? Any ideas...thanks for the feedback...
Greengiant
Greengiant
