fletchermerc1996
Thread starter- Joined
- Nov 24, 2009
- 19
Hi guys,
A quick question for you.
I purchased my boat about 6 months ago and have used it a few times (and had a great time!)
As it says above, it has a '94 135hp Blackmax. I have had the impeller and t-stats changed since buying it and it generally runs great.
I have the usual Quicksilver throttle also.
My question is, should there be a beep either on the throttle of the engine when starting the engine to indicate that the alarms are working? It has never done this, so I'm concerned that they may not be working.
The oil injection system has been disconnected, and I pre-mix, so I wasn't sure if they previous owner may have disconnected the alarms to stop the low oil alarm going off all the time? Is this what is normally done?
Hopefully you can give me some information and tips on this matter!
Thanks again for your time!
