garage floor paint on deck?
osborn159
was wondering, has anyone used the 2 part epoxy garage floor paint in a boat, if so how durable is it, i ask because i have a kit left over from when i did the garage floor and dont want to spend the money on something that i may already have and can use. experience/opinions????
Isaacm1986
Re: garage floor paint on deck?
I used a 1 part expoxy based garage floor paint on a boat deck before and it worked well. I was happy with the results.
ezmobee
My concern would be that it wouldn't take to flexing much being that it's designed for concrete. However it is epoxy so it should be ok. I'd love for someone to try it and document it and report how it holds up. (No offense Isaac, 1 part ain't the same stuff :))
osborn159
looks like i'll be the guinea pig on this one, once its done i'll post, maybe by then i'll have a camera and be smart enough to post pics, and report on durability
Dennis
ondarvr
I'll give you the same answer on this site as the other one.
The can typically says they aren't designed for outdoor use, epoxies don't do well in sunlight and will turn yellow and chalk much sooner than other types of coatings will.
I've seen where boats with this type of paint will start chalking and leave powdery residue on whatever it comes in contact with, shoes, pants, towels, skin, swimwear, etc.
LeftCoastJeff
That would suck to have to remove.
LCjeff
Isaacm1986
Oh I know the 1 part is not the same stuff. when I got the stuff it was on the clearance rack for $6 a gallon. I used it on a boat i was selling. the finised product turned out nice, however i do not know how it held up.
ondarvr
Garage floor epoxies also tend to be of lesser quality, they're typically highly thinned with low cost solvents, this results in a less water resistant coating. Because they don't cure as well, they may be able to flex more, but have less strength. The only part that really matters is the chalking and yellowing though, this may, or may not, be important, it all depends on what your expectations are.
