Hello, first post.
I have aquired two large pontoons, 24' in length. Don't know if I have the Insert Image thing right, but here goes,
I was given these pontoons because they leak. They have some pinholes scattered along the water line, apparently caused by electrolisis. Perhaps it was copper antifouling paint on aluminum, or a faulty electrical connection but regardless of the cause the point of the post is how best to repair.
After getting many suggestions such as riveting a strip of aluminum embedded with 5200 caulk, to fiberglass and epoxy patches, the plan I'm most comfortable with is to remove the paint, clean/neutralize the aluminum and then completly cover the hull with fiberglass imbedded in Gluvit.
I know this may run in excess of $1,000 for materials but I believe the end result will be worth it. My main criteria is to have a repair that is thorough and done right the first time.
If the picture did not post perhaps the little one below is viewable. It shows how I have removed paint from the front of one of the pontoons. I don't want to start a discussion on the cause of the holes but am only looking for advice on doing this repair in the manner that will give me the greatest peace of mind.
Thanks for reading
Thanks for reading
