6hp johnson steering bracket 1972
georgedexter
Trying to remove the steering bracket on 1972 6 hp. Need to get to bolts to remove Power Head. Need to remove Power Head to fix shift lever. Okay,I took nuts off of rubber mount studs,do these studs come out to remove bracket? Can't find diagram online. Plus I read that one bolt on power head is hard to reach. Any help appreciated Thanks.
F_R
Re: 6hp johnson steering bracket 1972
All of the powerhead bolts are accessable without removing anything else. You are overcomplicating the job.
jay_merrill
There are six bolts that are inserted from the bottom-up, into the powerhead base. Look for them under the flange at the top of the exhaust housing. You will also have to disconnect the throttle arm on the port side of the motor, as well as the fuel line and the choke lever.
If the problem with the shift lever is that it is "frozen," the initial problem is probably that the grease in the passageway from the "zerk fitting" (it isn't really a zerk, but just a part of the lever casting), is hardened. Once you get the shift lever out of the exhaust housing, be sure to get rid of all of the hardened grease - you may have to use some solvent to do this. Failure to do so, will just result in reinstalling a part that you can't properly lubricate and the lever will eventually get stuck again.
If the shaft still feels excessively tight in the bore that it is inserted into, after cleaning out all the old grease, use some emory cloth on it to get rid of exfoliated aluminum. You may have to knock the scale off of the walls of the bore in the exhaust housing too.
