Mercury 90 ELPTO
hillbillyjr
does anybody have any experience with this motor, does it have any major problems. i am looking into to buying a 2003 nitro 700 lx with the mercury 90 ELPTO, with this motor do good on this boat and is it enough power
achris
More fish than mountain goat
Re: Mercury 90 ELPTO
Not familiar with the boat (a few more details would have helped, like length, cabin or runabout, material)... Very familiar with the engine.... excellent product...
Chris..........
oldgradywhite
Its a good motor. Not the best idler or the smoothest being a big bore tripple but a good motor. No big durablity problems. Jest do that maintanice and it will last for a great many years.
mikeneal
I have a 99 version of same motor with about a zillions hours on it. Good motor, idles little rough no matter what (old, big bore, carb and 2 stroke).
Texasmark
Mine's an '02 version. Agree the big bore makes for a rougher idle than I had with my 6 cyl tower of power.....talk about a sewing machine. Mine sits up for awhile between runnings and on first startup it's thirsty. But once you run it for the day, it starts before you can get your finger off the key and in tight turns, where I can get the prop to vent some, it will turn 6000 without blinking.
I bought it used 5 years ago and replaced plugs once, replaced a stuck closed stat (bad when I bought it), and had one power pak go out (thermal problem....only failed when engine was cold....tough little sucker to catch but I did).
Previous owner said he replaced the impeller. At idle it will shoot pee at least 1" deep into the water. I run in clean water and turn the engine over at least once per week when not in use so I'm not worried about the impeller.
I change the LU oil annually and keep Sea Foam in the fuel.
One thing it does do. At idle rpm's in F with my SS 24P XL Ballistic prop (heavy and lots of pitch) I get clutch dog rattle. Don't get it with lighter weight props with less pitch. It's primarily a nuisance when driving onto the trailer but I get by it by shifting back and forth between F and N. I could put the little pukey props on and not have it, but I like the performance with the 24P and loading on the trailer is a very small part of the outing. Obviously the 3 big bore cylinders are causing this but what the heck.
Mark
