i have replaced the head with a rebuilt one,replaced the switch box,new,new starter switch,recterfier is working fine,coil shows good,dist. cap has new rotor installed ,including a new carbon brush,and i still am not getting any spark to the plugs,i have taken the wire from the coil to the dist. off and shorted it to ground while trying to start it,and get no spark from that,even took the green wire going to the coil off and grounded that,no spark coming from the green wire,something is telling me that this new switch box is faulty.Can u tell me how to test this switch box?please,
dist. side had
black tab-top
white tab-middle
brown tab-bottom
other side has
white-bottom
red-second
brown-third-i have never hooked anything to the brown,
green- top
How can i test this to see if it is good or not?
Thank you for your time in reading this,frusted trying to be a fisherman.
dist. side had
black tab-top
white tab-middle
brown tab-bottom
other side has
white-bottom
red-second
green- top
