Compression
8th of 9
What should the compression be on a 1973 25hp Johnson outboard?
Thanks
muskrat
Re: Compression
Both cylinder should be about the same,but not more than 15psi difference..
jonesg
Re: Compression
Thanks
If its elec start 100psi+,
hand start is lower,
I can't pull mine fast enough to show more than 70psi.
But they need to be close, rather close than higher is better.
2 at 90psi is better than one at 90 and one at 140psi.
JB
Re: Compression
Both cylinders in a 10-15% (not 10-15psi) span. psi are irrelevant.
Check the Top Secret file for detailed instructions.
8th of 9
Re: Compression
Thank you all again for the helpfull info, I'm new to the outboard motors and have experience in automotive so I just have to get used to how everything is and should pick up a manual :D Thanks again, until next time, have a good day.
