Dylan's Dad
Thread starter- Joined
- May 4, 2007
- 9
Ya'll have probably answered this already from some of the post iv read but need to be sure .
I replaced the impeller with a complete kit ,housing ,stainless bottom plate, the stainless cup, I noticed it did not have the rubber seal on top of the impeller housing and shifting rod when I took it apart that came in the kit which I installed ,when i went back together with it ,I also replaced the bottom two exhaust gaskets .
I crank it in a big clear storage bin I got at wallmart ,which is just the right height that my whale tale sits on it ,when full of water the seam is above the water, where the upper half of the lower unit and gear case meet.
when I cranked it water sprays out of the three holes in the front of the lower unit 2 point down 1 drilled on each side of the shifting rod cover that are coming out the stabilizer fin and 1 that points straight out toward the boat right at the seam ,these are spraying pretty good and i dont recall them doing this before .
i have been looking at some of the other post and hope its because i have the seals in it now between upper half of the lower unit and the pump, and shift rod ,also new exhaust gaskets ,giving the water no other place to go , and that this was suppose to have been doing this all along .
Thanks
Thanks
