Frankiea87
Thread starter- Joined
- Jun 18, 2008
- 96
hey guys i have a 1987 mercruiser alpha one drive.. 1st question is...when i connect the lower unit to the upper unit, where the shift shafts connect to eachother, should be in forward gear while putting the two halfs back together?
2nd question- i had oil leaking out of the yoke and u-joint area. so i need to replace a seal in there im thinking its a few or just one? i looked at http://www.boatparts.ca/mercruiser/upper_gear_case.html and noticed number 20-23 is what i need? or i believe just 23?
3rd question. the bellows currently on the boat has the straight tube style but is pretty loud while in water. i would like to change over to the standard type so it will exhaust through the drive. i looked at http://www.boatparts.ca/mercruiser/transom_kits.html and the bottem is what i currently have (that style) can i replace it with the top kit?
anyone with help thanks... i appriciate it
