windchimesforme
- Joined
- Mar 9, 2010
- 2
Hey guys, first post, I've been reading for while and couldn't find my problem solved. I figured I would throw an issue into the mix with the hopes you can all help solve it. I am new to this and I'm sure i'm going to leave important details out. but here it goes... I have a 2000 Seastrike 18 ft center console with a f100 99 Yamaha 4 stroke. It idles bad out of the water and pretty bad in the water. If you give it any type of throttle it seems to sound and work great. It tops around 5600 rpm and runs/sounds awesome. it shakes a bit in idle in N or in gear. I took it to the dealer. He is saying a carb issue. 185 comp. all cyl. good spark. all mait recently done. fuel/water sep, fuel filter, plugs, oil, gear oil, fuel with no ethenol, carbs were gone through a year ago and the boat has been used alot all year long, at least once a month or more. I have taken it it 5 times this month and it gets me anywhere I want it too, starts right up when warm, but the dealer claims at idle it runs on 3 cylinders, I don't want another $800 carb job! is there anything I can try to clean out anything stuck in the carbs/needles etc. I bet its something simple that wouldn't require that kind of money! I love the do it yourself approach, but I don't know much about carbs... All plugs before I replaced them were lookin good and all were colored equal. He pulled the bottom wire and no idle change like the other 3 cylinders at idle... fuel lines all look good from what I can see. This is probably a simple fix, I just need some ideas to get me busy. No manual yet, I'm working on it. Bought the boat a few months ago. Let me know thanks!!
