Evinrude 14 hp ve14rccs
Hey i have a 1988 evinrude 14 hp i had just bought it and has been sitting for a year or two and she ran fine for awhile and now when i put her in the water (Shes on a 14' lowes aluminum FB) she runs fine for a minute but the she bogs down and with the throttle turned over at full she goes about half speed and i can hear something either knocking or clicking should i say any help would be amazing thanks
bktheking
Re: Evinrude 14 hp ve14rccs
Did it sit a year or 2 with gas in the carb, sounds like its due for a carb service
Yea im really not sure but i am about to rebuild the carb tonite or tommorow but that wouldnt explain the knocking would it? thx
bktheking
Pumping water well, knocking and half throttle sounds like its overheating ,only takes around a minute WOT for it to start that.
we did have over heating problems as well but we replaced the water pump and it wasnt that it seemed to be plugging up but we put a bigger hosing on it and now it pumps out water real well ...i felt the water and it wasnt hot its self
bktheking
You need to check the motor temp when it does this, either by touch or a laser thermometer. Telltales only indicate that the pump is working, doesn't indcate if the thermostat has failed or you have a blockage somewhere,the telltale is before the stat. I still think its overheating.
ive touched the blocked my self it never showed any signs of overheating anymore would heat cause the knocking sound
bktheking
Detonation (also called "spark knock") is an erratic form of combustion that can cause head gasket failure as well as other engine damage. Detonation occurs when excessive heat and pressure in the combustion chamber cause the air/fuel mixture to autoignite. This produces multiple flame fronts within the combustion chamber instead of a single flame kernel. When these multiple flames collide, they do so with explosive force that produces a sudden rise in cylinder pressure accompanied by a sharp metallic pinging or knocking noise. The hammer-like shock waves created by detonation subject the head gasket, piston, rings, spark plug and rod bearings to severe overloading.
Some engines, such as liquid cooled 2-stroke engines found in snowmobiles, watercraft and motorcycles, have a very common detonation failure mode. What typically happens is that when detonation occurs the piston expands excessively, scuffs in the bore along those four spots and wipes material into the ring grooves. The rings seize so that they can't conform to the cylinder walls. Engine compression is lost and the engine either stops running, or you start getting blow-by past the rings. That torches out an area. Then the engine quits.
Now the big question, you are running 50:1 2 stroke oil mix in the gas? It could also be a really gummed up carb causing it to run lean. But you need to solve it before you run it again or you will do damage.
bktheking
I added to my post: carb could be gummed up bad causing a lean condition.
k im about to rebuild the carb right now but i know it cant be caused by heat as i have felt the engine and have inspected it
bktheking
Well all i'm trying to say is that most motor that go from running well to knocking is either a lean condition or overheating or complete engine failure. If you are certain it isn't overheating it's more than likely a lean condition. Clean er up and see how it runs, let us know.
bktheking
I hope it solves it for you ,nothing would drive me crazier than a sick motor.
yea im 16 and love to fish it totally kills me i have a 14' lowe flatbottom with that 14 hp evinrude on it i love hittingthe redfish in canals
