mechanical fuel pump
betayv
hello there 1984 mercruiser 228/305 mechanical fuel pump, what is the difference between a automotive pump and a marine, and is someone have the marine part# I would appreciate it. thanks.
Gary H NC
Re: mechanical fuel pump
do NOT use an auto pump! If it fails it will dump gas in the bilge!
The marine pumps have a small hose that if it fails it dumps the gas down the carb.
Your local Napa can match it up with the correct MARINE pump...
betayv
thanks for the info I already found the marine pump I just was wondering about the diference. thanks anyways.
betayv
hello and thanks for the help hey my fuel pump has only 1 out 1 in connection, the 18-7283 has 3, 1in,1 out and a small line on the side what is that for and If I get that one can I just block the outlet with a rubber plug thanks.
Bt Doctur
DO NOT PLUG IT,that is a diaphram vent that usually has a small hose that runs up to the carb.It`s purpose is to tell you the diaphram has ruptured and is taking that fuel and dumping it into the carb instead of the bilge.
betayv
a okbut my carburetor dont have a connector for that hose. what can I do.
Gary H NC
If it does not have it then someone put an auto pump on it!
There should be a plastic line that runs from the pump to the back of the carb.
Could be an auto carb on the boat too...geeze!
Post some pics of the carb and fuel pump.
PiratePast40
That's one of the hazards of owning an older boat. Who knows what modifications were performed or what was done to "get by for the moment"! The leak detection hose most likely is connected at the spark arrestor and not on the body of the carbureator.
Here's a link to a list of Coast Guard Regulations and Federal laws that discuss boating safety: http://www.uscgboating.org/regulations/federal_regulations.aspx
Here's another Coast Guard publication that's a little easier to read. It has some plain language about marine fuel and electrical systems: http://files.dnr.state.mn.us/education_safety/safety/boatwater/backyardboatbuilders.pdf
These should let you know what to look for to see if you're meeting the safety standards.
betayv
ok here is whats going on, the fuel pump is marine here is the link this is my fuel pump http://www.go2marine.com/product.do?no=85335F&WT.mc_id=gb1
Now my carburetor Im 100% sure is marine is a rochester 4 barrel I send it out to the shop to be rebuild and according to them and the carburetor number is marine not automotive, I will take a look tomorrow on the carb to be sure is a fitting back there.
Gary H NC
They used Carter and AC fuel pumps in those years if i remember.
The fitting on the carb should look like the fitting on this one,
Top left corner of picture with the arrow...brass barbed fitting....
betayv
ok thanks gary tomorrow I will check as soon I get the carburetor back, I will get the pump tomorrow the one you show me early, then I will post back, I just found a carter weber carb that was in a 1996 boat, very similar as the one in your picture, my engine is like I said 1984 the rochester doesnt have a electric choke, hey gary just in case if in the future I want to use the newer carburetor what I do with the electric choke? and do you think the intake manifold is the same? and thanks again for your help.
betayv
I found a picture of my carburetor and the fuel pump here
here is the carburetor that is on the shop
Bt Doctur
The arrow shows where a glass sight bowl should have been.This is a older version of a dual-diaphram pump.The sight glass was changed to a clear hose that went to the carb on later fuel pumps.
betayv
ah ok bt doctur thanks for that info.
Gary H NC
Ask the carb rebuilder.If that fitting is not there it should have a plug in the hole where it should go.
Take the plug out and the fitting should be a pressed in fit.
Get that straight and get some clear pvc line for it.
The clear line is so you can see if the pump ever fails.
Was there a spacer between the carb and intake? The fitting could be on it.
betayv
thanks gary I will do that tomorrow.
