electolasis show through cold tar epoxy
ba_50
I was wondering how effective cold tar epoxy is on aluminum. After applying, a month or so later that white powder look of electolasis starting showing up. Thanks.
steelespike
Re: electolasis show through cold tar epoxy
I think we need a little more info.Are you in saltwater?Never heard of cold tar epoxy?
You need anodes and the various components need to be bonded.Electrolosys occurs between 2 dissimilar metals.If they are bonded ,connected together, it minimizes electron flow.If your in a marina wiring faults or a neighboring boat with a problem can agravate corrosive damage.
ba_50
Cold tar epoxy is supposed to make your aluminum like steel. It's been around for awhile.
this boat has been in saltwater and the anodes are gone. I would think this problem would occur in both salt and fresh water.
Bob_VT
Coal Tar Epoxy (not Cold ;)) is made for extreme marine environments but it is considered "old school" technology. If the aluminum was not properly prepped then yes..... things could react and start to show through.
If youe anodes are gone....I would replace them.
ba_50
How is it prepared? Can the electrolasis be neutralized? Is there something better than cold tar?Thanks.
