How to fill trim unit with fluid?
Fish929
Guys, what's the best way to fill a tilt unit? My fill plug/hole is horizontal so I'm spilling about 75% of the oil. Makes me think I'm doing it wrong and there must be a better way.
It's a 2000 50HP.
Thanks!
Re: How to fill trim unit with fluid?
Make sure the motor is level, and tilt it up all the way. Now let it sit 10 min to allow the air to bubble up. Refill, install plug and cycle it down and up. Repeat until all the air is out.
i use a bottle with a hose connected to the top, that a hamster water bottle, and put a hose on the spout.
ezeke
Be sure to use the trail locks to support the motor whenever the fill plug is out.
Fish929
Thanks guys. I still don't understand why they made the hole face horizontally.
Last question, when u say lock it in the up position, how far up? The locks/supports only hold it about half as far up as it'll go. So that far or should I put it up as far as it'll go and put something like a tall sawhorse under it?
Thanks!
ezeke
That's fine as long as it's supported when you have the fill plug out.
Fish929
So put it up high with the sawhorse?
Thanks
Hdog412
I just refilled mine, I used a turkey injection syringe, you can't do too much at once, but you won't spill much
Seon
I too used the same method but with a turkey baser with the bulb on the end. I bought it at the 99 cents store. ;)
bignefan
I used a sprayer from a spray bottle screws right on the fluid top,then adjust to a stream.It take a while but you won't spill any. I've tried the turkey baster and still had spillage do to air triing to escape
