1984 Volvo Penta 2.3 carb problems HELP
Robbie5374
I have a 1984 sunbird with a 140hp 2.3 volvo IO. It has a single soledex not sure on spelling. It will only run when we hold the float down with something. if we push it all the way down it dumps a ton of gas. and as we decrese it delivers less gas. we had the boat running for over 10 mins doing this and ran great through all rpms. any ideas would be very helpfull thanks. you can email or just re post.
Don S
Re: 1984 Volvo Penta 2.3 carb problems HELP
What is the model number of your engine, it should start with AQ
Robbie5374
I belive aq230 i know the 230 part is rite.
Robbie5374
It runs GREAT when we hold that float down. I dont have much info on the motor. I was told buy the guy i got it from its a 140hp its a 2.3 im sure its something simple we just cant figure it out. it has a needle valve that the float rests on if that helps at all
Ayuh,... Buy a Carb Rebuild Kit for it,+ Rebuild it...
It's AFU,+ Needs it...
Robbie5374
How hard is it 2 rebuild the carb? Im pretty good with my hands ive just never done it b4. Every thing else seems 2 work great execpt that little problem with the float. is there any thing else i can do besides rebuildin it?
Ayuh,... I suppose you can stand there holding it...... :rolleyes:
Robbie5374
Haha funny. How hard is it 2 rebuild that model and also do u know the cost? any 1 else that reads this i would love extra adivce.:)
Fishermark
Carbs are not terribly difficult, but you need to be precise in the cleaning, etc. Take your time and make plenty of notes - take pictures even, as you go along. Most of the rebuild kits will even have some simplified instructions.
Robbie5374
Do you also agree there is nothing else i can do? Rebuild is what has 2 be done? the carb is clean as a wistle it was done about 14 months ago n boat was only ran a few times. it just has something 2 do with the float or that neddle valve.
Ayuh,... In Rebuildin', the Float will be Meassured,+ Set to Spec...
And,...
The Needle,+ Seat will be Replaced...
Robbie5374
when you say messered what do you mean? could i just ajust the old float n replace the needle vavle?
Ayuh,...
measured [ˈmɛʒəd]
adj
1. determined by measurement
Usually with a rather short Inch-Stick...
The Carb Rebuild Kit will have the instructions,+ in them are the Specs...
And,...
You're gonna Need the Gaskets to do it Right...
Robbie5374
so i could bend it up or down and that could possible help?
Ayuh,... Common sense, logic,+ deduction would lead most folks to that assumption...:)
Robbie5374
should i bend up or down? and also how much?
Ayuh,... Dude,... Did you download the Manual Don so graciously provided for you,..??
Did you Read it,..??
Stepaway from the 'puter,+ go take the carb apart,+ LOOK.....
