wires from Fuel Tank
clasavi
hello,
i have a '98 Mercruiser I/O 350 MPI.
from the gas tank, there are three wires. i found the green wire disconnected in the back of the boat. does anyone know where it hooks up to?
mciaio
Re: wires from Fuel Tank
Where is the other end of the green wire? What other wires are on the tank and where are they connected?
Bt Doctur
In most cases that wire runs between the tank and the deck fill ,reduces the chance of a spark
Black as
hello,
Green is commonly an earth wire but most important is your fuel gauge working ?
clasavi
yes, the fuel cage is working you. I looked around the deck fill and can't seem to find where it may have been hooked up. assuming it is the ground, which i am sure it is, any idea how i should reconnect it?
