Hello -
I recently purchased a 1986 Evinrude 90hp VRO (disabled). The problem I'm having is that after starting, or revving at all, the engine is idling way too high, like too high to shift into gear without blowing the tranny. I've been running it with the cover off to manually push the linkage down as far as I can so that I can get it into gear. I have already adjusted the control cables as much as possible, but it is still not releasing enough. My question is, there is an adjustment screw/nut that will allow the throttle(s) to come back all the way down regardless of the position of the stator pushrod bracket thing (please excuse my lack of terminology). What does the pushrod going to the stator do? can this and the throttle position be out of synch?
Thanks!
Thanks!
