Replacement Locking Stud Nuts - 307160
boldtr
I am working to reassemble my lower unit from my Evinrude outboard. The service manual says to replace the locking stud nuts. Most online parts stores want ~$5 for each nut. This is OMC PN 307160.
Is there anything special about these nuts?
Can I just purchase replacement lock nuts from a hardware store?
Do I need stainless? This motor will not see salt water.
F_R
Re: Replacement Locking Stud Nuts - 307160
There is nothing exotic about them. Nylok nuts from the hardware store. Stainless doesn't cost that much more, so use them. If you have any Locktite, a drop of that will work just as well as new nuts.
More importantly, be sure to use a torque wrench and tighten them to specs. Shoot for the low limit on the numbers. Broken studs are common. But they are often caused by a bent upper gearcase. Your manual should show how to check it.
boldtr
I have the manual with the torque specs and a torque wrench. Thanks for the guidance on shooting for the low-end to avoid breaking a stud. Thanks for saving me $10.
