Re: Problem Turning Engine
At least you had some good news and the power head and lower unit is OK.
I believe the bushing helps keep the shaft centered to keep the strain off of the pump and seals, probably will run without it but they put them in there for a reason.
Hopefully you got a title on the motor when you bought it and that should give you the serial #. Hot motors usually do not have the tags still on.
Well I said that and now I can not find the title to my C40 I found the 35 Johnson but the only thing I found on the Yamaha is the paper worksaying I paid the fees. I found the title for the boat but not the Yamaha motor.
Is there a motor title in the state of Texas still?
