No Spark
tonyWRIGHT
i have a 1993 15hp mercury that is not getting any spark but it is getting fuel i check coil packs and there is no cracks and appaers to be find i have no clue what could be wrong help please
zepljak188
Re: No Spark
hello i have same problem with my aq130c volvo penta before the winter it was working just fine but today i found out plugs not firing
please we need some help if i found anything i will post it
verado7
Re: No Spark
you will need a voltmeter with dva you can a meter with it built into the unit for anything from 150-800 bucks ( 150 bucker will work fine ) or you can buy a dva adapter that plugs into any voltmeter for about 60 bucks - iboats sells them as as-well as cdi electronics .
you wont be able to read the voltage off a standard voltmeter without the dva feature - with it you'll have no problem finding the fault .
use the specs in the book which you can get from the parts guy's usually a SELOC brand manual .
