Martman
Thread starter- Joined
- Aug 23, 2009
- 60
The boat I am looking at was subject to a good compression test. I did the test. The left bank was 120, right bank was 60, and 75. The owner claims he did that head gasket last year because of a water leak. When I asked him if he torqued them. He indicated he did not. As both right cylinders are low that could indicate a poor head gasket job? I can do the work myself. But should I demand we pull the head off to check for other problems that may have caused the bad compression test. Scored cylinders etc.
Do you replace head bolts on these engines when doing a gasket job?
Thanks
Thanks
