WOT stalling
angler0520
i have a 2005 honda 90hp i have had the motor for about 8 mounts it has always had a problem when i am puting it on the trailer it has always staled out when i am trying to run it up the bunks on the trailer like when it is under any kind of strain it stals now i am having the problem when i run WOT it starts to stall does anyone have any ideas of what kind of problem i have
kend301
Re: WOT stalling
Sounds like a fuel problem .. more throttle engine needs more fuel . Also check timing , little or no advance can have the same effect. I would start there .
Flakeys
Re: WOT stalling
I agree with a fuel problem. My honda carburetor book states that the most likely cause for this symptom is restricted or plugged main jet(s). Since you have 4 carbs, i'd advise a overhaul/rebuild of all of them to ensure you get the faulty one(s). Then a synchronization of all 4 is required to ensure they equally share the load throughout all speed ranges.
Hope this helps.
angler0520
Re: WOT stalling
to synchroniz the carbs i need the set of vacume gauges corect? if so any idea where to get them?
Flakeys
Re: WOT stalling
You might ask your local marine dealer or Honda dealer. I've heard of others using motorcycle vacuum gages, but don't know how well or if they worked.
