Re: points wont stay gaped
the screw with the head on it should be the one to hold your points down,the one with no head should be the eccentric ,it adjusts,,,,,,,,make sure youre on the high side of the lobe on the crank,then set that side ,then turn crank 180 to put other set on high point of the lobe on the crank,,,,turn the crank a few times,check it again,,if its right,you should be good to go if your coils are good,and you have no connections touching the armature plate,this will ground it out,dont ground any of the wires going to the point sets or you will never get fire and poss burn up your coils ,hope you have good luck with it
